Qc Flatlander
Need help !...........what kind of rotrex blower are in those kit :
-Yamaha Nytro 180HP kit (from Yamaha parts website and made by MPI)...........C8 or C15 ???
-Yamaha Nytro Stage 1 kit directly from MPI............C15-60 ???
Maybe a good question for Matt.........I want the best set-up with pump gas (91 Octane) and stock compression. (trail sled only).......
Regards !
Regards !
A.Granath
- Sep 5, 2013
- Sundsvall, Sweden
- Sweden
- Yamaha Viper MTX 162" MCX Turbo 190
- Sundsvall
Qc Flatlander said:Need help !...........what kind of rotrex blower are in those kit :
Regards !
On the 180hp and stage 1 MPI uses Rotrex c15-60.
Info from Rotrex:
http://www.rotrex.com/media/dca8fd09-98 ... 0Range_pdf
The 180HP kit makes 4-7psi @ sealevel (155-180hp) boost depending on gear ratio of pulleys, if you want to push it some more you need to use race gas and add a intercooler.
Last year i used 28/28 gearing for about 6 psi (sea level) and only use 92 premium, if you are unsure of the quality of your fuel you better go for a lower gearing to have a more fail safe setup.
