RX-1 Liter
- Apr 14, 2003
- Chautauqua County, NY
- 2017 RMK 155"
Is there enough cable (throttle, break, etc) to intall a Rox 3.5" adj riser on the stock MTX riser?
nytro addict
I have the 2" rise on my XTX and its all good. I just read on the fx nytro genaral talk. And some one said for the 3.5" they had to route the throttle cable from behind and then they had enuff cable.
outofbounds
- Feb 19, 2009
- Leavenworth and Bellevue Washington
You can add a lot of cable reach by removing the right side panel and cutting a channel out of the black plastic panel (the cables run under the panel on their way up to the post).
I installed a 2" block and used the 3/3" Rox to move the bars further up and quite a bit forward.
Re-routing is probably not too hard but cutting the plastic took less than a minute (dremel with plastic cutting wheel).
1-Liter,
I know we pm'ed about this, but this might be the first place for you to start. There are a lot of MTX riders that will swear by the relocator:
http://www.ty4stroke.com/viewtopic.php? ... hlight=oft
And a lot of short track riders as well:
scmurs
scmurs
