Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
Does anyone have pictures of how they mounted the Rox billet aluminum handguard mount with PowerMadd handguards? on their sled? I thought it would mount between the handgrips and the throttle (like the PowerMadd ones) but the mount is too thick and the set screw is in the way.
http://roxspeedfx.com/product/rox-power ... mounts.htm
Thanks.
Thanks.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I have a set of Rox SpeedFx Handguards on my Nytro and mounted them inside of the throttle assembly (or brake assembly). Because of the wiring into the brake or throttle - one of the brackets was face up on the bar while the other was face down.
They are good guards. They offer good wind deflection and flex enough so the don't snap as easy as the factory ones.
Dumped the sled last winter in a drift and thought for sure I wrecked one side, flipped it over and it was fine. The factory one would have flexed and cracked or snapped for sure.
MS
MS
Cubby
- Dec 14, 2009
Do you have pics?
That is why I bought the powermadd brackets
s1d3w1nd3r1480
I have Rox ones on my sled now after bending a stock one last year. Swapped them out with the Rox I put on my 02 Viper (
should have switched them before I even rode it the first time). I have mine both mounted the same way on top of the bars. i will have to go and look and get pictures to see exactly how though.
Definitely better though as when I dump it carving or something the bolts on the handguards only bend slightly and can bend back easy. if the bolt ever breaks i can simply replace it instead of a whole handguard
should have switched them before I even rode it the first time). I have mine both mounted the same way on top of the bars. i will have to go and look and get pictures to see exactly how though.Definitely better though as when I dump it carving or something the bolts on the handguards only bend slightly and can bend back easy. if the bolt ever breaks i can simply replace it instead of a whole handguard
Cubby
- Dec 14, 2009
sleddog66 said:That is why I bought the powermadd brackets
I thought I was smart getting the aluminum ones! I can always sell them if I can't get them to work and buy the PowerMadd ones.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Cant get a pic to you until after the weekend.
MS
MS
- 15K
