Rox billet handguards
YamaBert
Hartford, WI
Will these handguards go on my 07 RTX and not have clearance issues when turning with regards to the windshield? I have the stock windshield on. Or would putting their 2" riser on help with clearance? As far as order quantity on this site, is a quantity of 1 mean the set, or both the left and right handguard, extension, etc? Thanks in advance.
http://www.roxspeedfx.com/cgi-bin/cart/ ... cat_id=279
I have the Rox handguards on mine too. The brackets are ok to use, They have to be on just right or they will pivot up and down cause there is only 1 set screw. I drilled and tap a new hole for another set screw to hold them tighter.
On there site 1 means 1 pair.
Rich
I have SKINZ outerwears on mine and ilove that i can put them in my trunk when not in use,it takes 2 sec on/off,i have 2'' risers and they don't touch! ;)!
I ordered a set from ROX last year and ended up not using there mounts couldn't get them to fit properly so I ordered a set of POWERMADDS mounts which fitted much better and you have to use a 2" ROX riser to properly adjust them to clear your windy at full lock and you keep all stock cable and brake line with a 2" riser...here are a few pics.
