roberterin
- Jan 18, 2010
guys i have an 09 xtx, 114 studs and bender racing clutch kit. i put the kit on and im not sure if the weights at the heel when wide open on the roller is touching the spider/shoulder of clutch? at FULL open (if that makes sense?) when originally put on bender said some sleds have to grind a little off the clutch to make clearance for the shoulder at full open for all three weights........not the nytro though (rx1, viper etc). they are AMAZING at bender but i didn't grind it because im paranoid i don't need to do it and if i do will i blow the clutch all to ShiiiT if im not EXACT with the grind???, how the hell can i tell if its hitting without taking it all apart and sliding it again???. the sled PULLS LIKE NUTS now but i think shes got more in the top end??? i get around 106mph on the speedo but only 8480rpm's (i think) MAX when its to the bar................should i get more rpm's???, does anyone have this kit on their xtx and can share input. kit came perfectly ready to be installed....i didn't even have to loctite the weights!!!!.....BENDER is great to deal with.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
You need to be around 8800-9000ish for rpms. You would need to remove some weight from the tip of the clutch weight. I dont now how much they put in so this is the most I can help with.
