rs nytro high beam indicator light
yamaha 10
Hi, I have an 06 Nytro er ,bought new last year. Only rode 1 day last year and twice this year. We noticed high beam indicator light doesn't work, probably didn't last year just never noticed. never seen one burn out,all connections seem tight. any ideas? How do you get in to change if it is out? Thanks P. S. I still have warranty left would this be covered?
Sorry, the manual doesn't address this specifically. It shows the main meter lamps as being a twist in base type. If it is the bulb itself, you'd need to remove the gauge assembly and there are several small phillips head screws on the back to take it apart. You may want to call your dealer if it is still under warranty. I would think it would be covered.
