RS oil capacity
With oil filter cartridge replacement, 3.2 US qt
Without oil filter cartridge replacement, 3.0 US qt
If replacing oil filter check and make sure old filter gasket is removed, sometimes they adhere to the engine block
Homer. In addition to the holding tank and the filter, don't forget to drain the oil from the bottom of the engine. Very near the filter is a plug marked by a triangle imbeded into the bottom casting. Remove the plug and drain there.
1 bottle of oil in the engine 2 in the oil tank
