RS Vector Rear Heat Exchanger?
http://www.pioneerperformance.net/ go here and click on the engine tab and the reax heat exchangers are at the top of the page. my buddy put one on his 05 RX1 last year and has not had any overheating issues since. my dad also has one on his rage...the other thing that these help with is ice in the tunnels...since my buddy installed his the ice build up in the tunnel is almost nonexsistant...i will most likely get one for my vector this summer...i know it says "viper" but it will fit. good luck.
deerhunter1 said:
Thanks that looks like just what I am looking for .
ST
EVE
Steve
If you get the rear heat exchanger,shim the tunnel protector another3/4 of a inch. The first time I had my sled outI put some good groves in the exchanger( did not leak) the reason the track lugs are too soft that allows the studs to extend farther
I am not shure what you are saying the two rails Up under the track you Want me to shim them down 3/4 is that so the studs cant get to the heat exchanger ? Why I am at it do they have a bleader in them to get the air out or how do you do it ?
Thanks again Steve
Thanks again Steve
Steve
There is a bleader stud at the back of the heat exchanger
oldyoung said:
Thanks again Steve
Steve
oldyoung said:
oldyoung said:
Thanks again Steve
Steve
oldyoung said:
oldyoung said:
oldyoung said:
Thanks again Steve
Steve
oldyoung said:
oldyoung said:
oldyoung said:
oldyoung said:
Thanks again Steve
Steve
