brad gilker
- Feb 14, 2016
- haliburton
- vk pro
Recently pulled my buddies rs venture out of the water. Changed all relays and voltage regulator.
Rinsed engine with oil 5 times, drained and vacuumed tank, put fresh gas in.
Starts and runs great, but after hard acceleration, it seems to go into a limp mode until rpm's go to idle.
Thoughts anyone?
Thoughts anyone?
- Jun 28, 2004
- Clinton, Wi.
Check your throttle free play. Sounds to me like the TORS is activating.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Ditto
brad gilker
- Feb 14, 2016
- haliburton
- vk pro
What is TORS? Thanks fellas!
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Throttle override system. I think. It's called that. Do a search on this site for adjusting TORS and you'll see what we mean.What is TORS? Thanks fellas!
It's how tight your throttle cable is. When your tours is activating and means your throttle cable is too tight.
brad gilker
- Feb 14, 2016
- haliburton
- vk pro
Thanks. It didn't do it before the sinking though
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
Well, weird things can and do happen after a sled goes underwater. Ask me how I know this.......Thanks. It didn't do it before the sinking though
probably the throttle block is full of water. does weird stuff when it happens. been there done that with a kill switch on an rx.
stubby
Drain the carburator bowls and use gasline antifreeze to make sure all the water is out of the system. Mine ran like that until I completely ran it out of gas and then drained the bowls and used fresh fuel. It would idle fine but then bog when applying the throttle.
