RS Venture GT Popping out of Reverse
saltr
Age
70
RS Venture GT
Hello All: Anyone experience your RS popping out of reverse while backing up? Going to check linkage tomorrow. Any other checks I should look at as to the cause? Thanks-saltr.
yes, the pivot bolt in the linkage needs to be tightened, happened to me this year. difficult to get to but it can be done with a couple of wrenches. A crows foot would make it easier. snug the pivot bolt down and you should be good to go! it will take at least 15 minutes cause it is really hard to reach and not much room for your hands.
Thanks for your quick reply. Will give it a look.
Not only did I tighten the pivot bolt, but I lengthened the lower adjustment rod. Seems to have remedied the popping out. Thanks again-saltr.
