This is just a FYI - Between myself and another friend, I have access to three 2007 RS Ventures - all with thee-digit mileage on the odo and all with loose mirrors. Each mirror has a pair of threaded studs affixed to their base, which are bolted down with two 10mm nuts. The nuts can be accessed by removing the triangular sections of plastic (held in place by one very visible phillips-head screw) flanking the instrument cluster. Once these pieces are removed, I was able to remove one mirror nut easily with a ratchet, while the other (the one closest to the corners of the headlights) required some patience and an open-end wrench.
Took the nuts off, removed the mirrors, applied a bit of Loc-Tite (none previously applied on the threads) bolted everything up, and am now back in business.
Scotth
- Jan 6, 2005
- Milwaukee & Land O' Lakes, WI
- www.rocketshoppe.com
Ya, had the same problem with mirrors loosening up on my '07 Venture. Had to fix it on the trail.
