RTX Owners and short windshield
Skydog said:
machzed
How much air do you run in the front when you drop her down for speed runs?
THank you Skydog
I actually forgot the psi....but look at my avatar,I was radaring during that picture so just let the air out till you get her that low....
a buddy of ours had another rtx there that same day which was slower then mine .....he was even LOWER then mine...i think if you get too low you get negative results.
the nice thing about when its that low is,when you look at angle of attack,then track where it hits sliders in front is straight...so you have no slider resistance infront.
I usually keep the A arms set to LEVEL or just slightly lower for my everyday riding...handles awesome there.
dan
i used a set of atv shocks from my quadracer on the front,made a very short limiter,then set the back of the rear suspension where i wanted it and measured the center to center distance of the transfer rod mounts and made one out of 1" square stock,suspension still has the 2 inches of travel required by the rules but it just moves up and down ,it doesnt transfer,on take off it would hold skis about 2 inches off the ice and pulled straight as an arrow every run,run a 05 machz all slammed down and pimped out with big aluminum wheels,244 chisels,speed track,the works supposedly and after about 1200 feet i went by him
and my thoughts on the low shield........looks awesome,use it locally but when it comes to my trips to quebec or other multiday trips i have a mid height snivel shield that goes on,you can see the taller shield in the following pic
