Musky Hunter
- Feb 21, 2004
- East Aurora, NY
- www.try-itdistributing.com
what is the purpose of that rubber flap over the carbs? Does it keep snow out, keep heat in, or something else? :itchy:
RobX-1
- Coldwater, OH
You are correct, they prevent snow buildup around the carb area. As for carb heat build up, others here have added a engine coolant shut-off valve to prevent flow of coolant through carbs when running in warmer conditions. I think with the carb coolant lines and the snow flap, you shouldn't have a problem with your carbs freezing up.
