Kachess
I pulled a bender turbo (and NOS) off our sled because it was hard to tune for elevation changes and oil consumption (quart per ride). It would lay down an oil smudge in the snow on hard acceleration. No sign of oil at idle or low speeds. I assumed the turbo was leaking it through its seals. Well, it still lays down a smudge without the turbo. It starts/idles fine, and runs at about 90% the power of our other stock one tons. Doesn't quite spool up like the others. The compression is better than our other sleds. I tried a leakdown test but can't find any obvious leaks. I've checked and re-shimmed a few valves. I looked at the piston tops/cylinders and they looked fine but looked like they were burning oil. The intakes are dark stained which I originally thought was from turbo oil but now figure it was caused by blow-by cycling oil from the breather back into the carbs. I now realize I probably should have gone and replaced rings while I had it partially apart. Could valves be a the problem? They looked tight (held solvent) when I had the head off. I'd appreciate any advice on what to do next? This sled's driving me crazy.
