blackcherrycamaro
10500 rpm immediately, tried different secondary springs , helix from Ulmer. Changing primary arms and secondary helix really woke sled up compared to stock but seems to run a lot more rpm at a any given speed than than it should, I have checked and inspected all ramps, rollers, bushings all serviceable condition or I replace if in doubt. Some people would not have issue, maybe, but it just seems to run a lot of rpm for the speed, running on regular trails in Southern WI, always 7000 to 10,000+ rpm , the sled is averaging 13mpg running this way, stock air box, had to replace seat O-rings in a couple of the carbs. Again motor runs great, but never really seems to shift down enough,
belt seems to be traveling up and down sheaves correctly any thoughts out there????
