sled_head2004
- Apr 28, 2014
I rolled my RX-1 and now I have no electrical whatsoever. The engine will not crank or make a noise. Checked the fuses and they all seem to be good. Any help??
Purplecoffin
Dumb question but.....did u check the kill switch. Don't ask why I bring this up....
sled_head2004
- Apr 28, 2014
I checked the kill button and the fuses, still no power. I noticed today in the light that the tac is frozen at 1200 rpm and my handlebars are all bent.
Purplecoffin
Where are you located? I have a bunch of stuff that could be switched out while trouble shooting if you're close enough
will the sled crank if you jump the solenoid? i had a bad ign switch that would not crank as it was broken inside.
sled_head2004
- Apr 28, 2014
Live in PA, jumped solenoid it cranked but seemed to crank slow so I tried starting fluid , but even with that it doesn't try to start would ignition make crank slow?
no sounds like a weak battery or it is flooded bad.
have you pulled plugs and checked for spark yet? might have mangled one of the wires for the kill switch and it is acting like kill switch is down. might have to bypass it.
sled_head2004
- Apr 28, 2014
Checked the wires and they seem ok coming out of the switch. How do I jump the switch? As for the plugs, I haven't had time to pull them out yet.
if i remember correctly, use a cotter pin to bridge the 2 brown wires and try it.
