vipermike2002
- Jan 19, 2006
- Barrington, IL / Rhinelander, WI
- 07 Attak
My 05 RX-1 developed an exhaust leak. After I removed the seat (and related) it looks like the problem is at the flange where the Y-Pipe(s) connect with the headers. After looking at replvement parts I made the discision that this kit on eBay would be the best fix.
http://www.ebay.com/itm/Yamaha-snow...MTX-/151222687529?hash=item2335931729&vxp=mtr
My question is how to I remove the Y-Pipes for repair? I see nothing obvious when I remove the seat. I need to be able to unbolt the Y-Pipe and slide it out. I believe I have to drop the skid? Any input would be appreciated!
This sticky has the info and pics you need
http://www.ty4stroke.com/threads/exhaust-donuts-y-pipes-step-by-step.52520/
vipermike2002
- Jan 19, 2006
- 07 Attak
Sounds like the rear suspension has to be lower and the exhaust bracket drilled out to get the Y-Pipe out?
Yes drop the skid. Drill out the bracket only if the bolts refuse to move that hold the Y-pipes. I use a torch and make them cherry red. They seem to come off easy then.
