RX Warrior 2005 jump start mistake what to do
kruger82
Sept-Iles, Quebec Canada
Hi guys,
I am new here. I just bought an RX Warrior 05 with 9500km.
Me and my friend tried to start the sled but battery was dead so we tried to jump start it and my super friend inverted the cable by mistake now the sled wont do anything what i have to check or replace?
Thank you
First off welcome to the site. Second you need to fill in your location as its a site requirement. Third main fuse is most likely gone check and or change it. Charge and or possibly replace the battery.
I do believe it is right beside the starter solenoid with some fuse holders should be at the top by the brake caliper. Now your going to ask me where the starter solenoid is aren't you. lol
At the top of each page there is parts list finder use it to find where parts are and the number if you need to order one. Also at the top of each page is a TY TECH click on it and then on snowmobile tech then scroll down and read all about your sled and others as well. Lots of good info here but you kind of got to help yourself and look for it.
With a volt-meter check the voltage of Your battery, it should be above 12V when fully charged. If lower than 12V attach a battery charger.
If Your battery have good Power, then you have a fuse blown or the starter or starter solenoid is shot.
