RX Warrior throttle not right
kc10acc
Upstate NY
I was riding my 04 Warrior and everything worked as normal. I got to the end of the trail, turned around, tried to get into the throttle and it won't power up. It almost felt as if it was not running on all 4 cyls. I replaced the plugs and the same thing still happens. It runs fine at idle and starts warm or cold fine and the plugs look good. It just does not run correctly when trying to produce power (chugs, sputters etc..) My dealer said its mos likely the TPS sensor or setting. Anyone experience this and does it sound like thats the problem? He made it sound like its a common occurence and that its not a hard fix and that it is not that expensive. Anyone?
Thanks in advance
I have had a smiler problem but it was that my crabs weren't sinked and some times it could be your throttle over ride dos it seam like you are starving for fuel
Your throttle cable needs to be adjusted. there's a switch that rides on the cable so if your cable loses tention it wont rev. over like 1000 rpm its a safety feature. I Had same problem.
