taylmeistr
- Dec 25, 2012
Newbie user/RX Warrior owner - I picked up an '04 RX Warrior late this summer and have done a bunch of work to get it up to my standards. It had the stock skis with 9" shaper bars on it. I bought a set of Yamaha Tuner skis along with 6" inner and 4" outer carbides. I rode it a bit last week with the old stock/shaper bar setup and it wasn't bad. A little darting and decent turning when road riding (ice/light snow) and decent cornering on lightly packed trails (ten inches groomed once). I then installed the new Tuner with the carbide setup described above. Turning was tighter and more precise on the road ice but darting definitely increased. I took to the trail and quickly found that my Warrior only wants to go straight!!! I had to slow down and creep through corners else I would have been in the trees... On the trail is felt like my skis and carbides just weren't doing their job.
I have read nearly every post on handling, suspension setup/tuning and the Tuner skis on this forum. So far, I have left the suspension settings the way they were when I got the sled (it seemed to work fairly well with the stock ski set-up). There is quite a bit of pre-load on the front shocks. The FRA is set at the hardest (third setting) and the transfer sits right in the middle with me sitting on the sled.
My first instinct (goal is to get happy with the Tuner skis) is to crank the limiter straps to get some more ski pressure. I am also thinking about dialing down the pre-load on the front shocks (taken from advice/posts in this forum). Am I on the right track here?
I weigh about 235lbs. and I am running a brand new Ice Ripper XT (pre-studded) 136" track.
Any suspension tuning/setup advice would be greatly appreciated!
