tim brandenburg
- Jan 1, 2017
- washington
- 2003 yamaha rx1
I was wondering if someone had a installation manual for bender turbo Yamaha rx1.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
You could try getting ahold of these guys.
http://www.fullpowerperformance.com/yamaha-2003-2005-rx1-rx-warrior-stage-2-trail-turbo-kit-4999-00/
Ken..........
Ken..........
tim brandenburg
- Jan 1, 2017
- washington
- 2003 yamaha rx1
thanks tried they did not get back to me yet
tim brandenburg
- Jan 1, 2017
- washington
- 2003 yamaha rx1
I have had my 2003 yamaha rx1 since new. I have always wanted a turbo for it. I found this rear mounted turbo kit on ebay. It has a hurricane performance box. no other marking but the turbo. If you had any information about it.
ersky
- Feb 6, 2009
- ont canada
- 06 apex gt s/c (sold) 04 rx warrior apex converted 2 stage bender turbo. 12 venture gt (getting old)converted to 11 apex
building a custom apex
if u still need the instuctions I have a set could copy and send to u
matt335
- Apr 19, 2025
- Chicago
- YamahaRx1
Hello, I’m want to build rx1 turbo, do you still have manual?if u still need the instuctions I have a set could copy and send to u
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
This is a seven year old thread, Ersky has not been on the site since 2018. You might have better luck if you start a new thread of your own
GT Mills
- Oct 26, 2016
- West Columbia, SC
- RX1
The Full Power Performance website is long gone, just searched today. Left a VM, hope to hear back soon...
Please help. Looking for ANY RX1 turbo install instructions, mainly trying to figure out what was done with the so-called "Pitot tube", which I can only figure out is an adjustable, fine-pressure PSI regulator connecting the charge (boost pressure) air to the carb bowl vents, effectively forcing fuel up the jets into the carb throats via the bowl overflow tubes. It appears the downstream pressure from these little regulators was only about 1.5 lbs, with tiny adjustments allowing for density altitude compensation.
One other question: Was the carb vacuum slide (outside air pressure) vent also connected to the intercooler and/or a regulator valve???
- 7K
