RX1 clicking noise
rednecksized said:
YammyRX1 said:
Check the brake rotor and all the bearings. I found that my parking brake caliper (lower one) was rubbing on the outside of the rotor and needed new pads, this could make a noise if the rotor has wear on the edges. I know this is the opposite side but rule things out one by one.
I think this is the same thing that happened to me today, now that i have my whole gearbox apart. Guess i should no better than to take apart and then read on here. One of these times ill learn my lesson. :o|
FYI- if you need parking brake pads for the 03 RX-1 they want to sell you the whole caliper assembly. If you look at the parts list for 2011 Apex they are the same pads and available separately. I hate the Yamaha parts numbering system!
