MTV 737
- Jan 9, 2008
Is there a grease fitting for the left side drive bearing around the speed sensor like my older sleds ? I only find grease fittings on the skis for my 05 RX1.
Thanks.
Thanks.
wienerwater
- Mar 1, 2007
- Northern British Columbia, Canada
Not on that bearing. You can pull the seal (carefully) and repack it thogh after taking off the small gear and sensor.
low slung
- Feb 16, 2005
I find a grease needle works great.
wienerwater
- Mar 1, 2007
I actually pick out what I can, old greae and gnats etc, spray it with brake cleaner well, blow with air, maybe repeat a few times, bow dry with air then use a grease needle and pack it with your fingers as best you can.
