Rx1 throttle cable
Cnaser
Northern Utah
I just installed 3 inch bar risers and was wondering if the apex throttle cable would work or what are some of you using thanks for any help.
I'm using a '05 RX-Mountain throttle cabel with 6" riser and nytro handelbars.
Like TT said, get the 05 cable, $22 cdn. It will work with your setup. I have a 3" riser, and a set of Fabcraft bars, alot taller than stock. The apex cable is different.
If I'm not wrong the '05 cabel is 2" longer than '03-04 cabel.
I also have the 05 RX-1M throttle cable with my current 2" riser setup.
If one goes to a higher 4" riser setup does the stock brake line and the other wiring running up the steering column reach ok?
Frosty
