Cnaser
I just installed 3 inch bar risers and was wondering if the apex throttle cable would work or what are some of you using thanks for any help.
TT
I'm using a '05 RX-Mountain throttle cabel with 6" riser and nytro handelbars.
Snobeel
I have an 04 rx with a 2" riser and I used a Mountain Max cable.
Like TT said, get the 05 cable, $22 cdn. It will work with your setup. I have a 3" riser, and a set of Fabcraft bars, alot taller than stock. The apex cable is different.
TT
If I'm not wrong the '05 cabel is 2" longer than '03-04 cabel.
Frostbite
I also have the 05 RX-1M throttle cable with my current 2" riser setup.
If one goes to a higher 4" riser setup does the stock brake line and the other wiring running up the steering column reach ok?
Frosty
Frosty
Trxster
Where did you get the 05' cable for $22?
