sea foam
Sea foam products are available at Piston Ring outlets(at least at Wall St) in Wpg & some of their other rural outlets as well.
ok, I volunteer to purchase and ship it to you if it is all right w/customs. You canucks will have to tell me if it will make it through.
There's a few tricks to getting stuff through customs;
1) include receipt and pay duty. Everything will go through unless its drugs or firearms.
2) stamp *gift* on it. They might still try to go into it, so double box it with the inside gift wrapped - use kiddy wrapping paper and put on a card that says "to Joey from Uncle Frank".
3) return it with faked warranty invoice and say *warranty replacement to customer* on the box.
For #3 its almost guaranteed to get opened. For #2, it'll still get x-rayed, so still no guns or drugs.
Magic Snake Oil is never cheap. Do you know how many wizzards it takes to make a batch of that stuff? :)
LOL.
CARB CLEANER - the spray kind. That stuff really is lethal and WILL dissolve carbon, BUT BEWARE, it will melt the rubber diaphram on the slides, so make sure its hosed in BEYOND the slides.
A couple of cans should do.... hose a half a can into each cylinder with the motor running with throttle at least a whole bunch open...
Maybe through the vacuum check nibs in order to keep the motor running instead of trying to run it with the airbox open.
uote="vgs"]Sea foam products are available at Piston Ring outlets(at least at Wall St) in Wpg & some of their other rural outlets as well.[/quote] ;)! ;)! Thanks for the tip, we deal with these guys and they have it so getting it will be a snap. :-o
As for the napa store not only didn't they have it , but if i was to get the part # they were not even willing to bring it in for me! :o|
