Seat Removal
bigal1951
St. Andrews, MB
Canada
2014 SR Viper XTX
2004 RX Warrior
I would like to remove the seat on my 04 RX Warrior. I want to work on the exhaust. I have the skid out already. Does anyone have any pictures, images or just some words on how to do this?
Go to the technical pages section. Go into the engine section and scroll down, you will find an article on how to install the maximum performance companies' exhaust system. this should have all the info. you need. Very easy to get the seat off.
There is a ton of good information in the technical pages. check them out!!
just remove the plastic wrap around trim and the tailight trim. There is 2 long bolts with 10 mm nuts that come down through flanges in the exhaust heat shield. remove those and the seat just slides off. The wire for the tailight is on the right side and disconnects under the plastic side panel below the tank.
