seat removal.
stinx
Massachusetts
what are the steps to remove the seat from my warrior? I checked the FAQ section but for some reason my computer cant open the manual section.
If anything like 03 RX you must remove exhaust tip covers three socket heads per side. then unbolt taillight trim piece (2) bolts. After you remove taillight trim there are two nuts you must remove that are connected to the seat then unplug seat near front right side. Now lift up and back at the same time.
Allen head is the same as socket head. You might be thinking of Hex head that you use a socket to tighten or remove.
thanks guys!!!
