rx1warrior2004
- Jan 1, 2013
I need the ajustment for the secondary clutch for a rx warrior 2004.... I just use in the trail and I think I have a cam for vector !!!
thanks
thanks
tedgoesfast
60 or 70 degrees whats your back spring
rx1warrior2004
- Jan 1, 2013
ok thanks ted
do you think I have 8BV51 (45 *) in the secondary clutch is a good alternative ? only trail
my spring is the all black with a white line !!!
rx1warrior2004
- Jan 1, 2013
Nobody?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
If want some thing better get the stock cam from a05-13 they have 51-43 in them an they work great.
A white secondary spring with 60 to 70 degrees of twist should work awesome for your sled. Are your buttons in good shape or see if some are missing on the secondary.
rx1warrior2004
- Jan 1, 2013
Thanks guys, i have 3 brand new buttons and i will looking for 51-43 cam....
With this cam, i will know the top speed? What is the adjustment with the spring?
