Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
What is the stock setting for the secondary on an 04 Warrior?
Has anyone tried different settings? And how do they compare with the stock settings? Thanks
welterracer
I belive the stock setting was 3+3.. Or 60% twist..
Secondary spring controls back shift.. I know for a while i had mine at 3+4 or 70% twist... Worked really well out of corners... NOt that it was ever bad..
Buckeye
- Lakes Region, NH
welterracer said:I belive the stock setting was 3+3.. Or 60% twist..
There is no 3+4. The secondary spring also impacts the upshift.
welterracer
Buckeye said:welterracer said:I belive the stock setting was 3+3.. Or 60% twist..
OOOPS... I ment to say i had it set at 2+6 or 80% twist.. I HAD TO CHECK MY NOTES...
HELIX IS MARKED IN INCRIMENTS OF 3...
MY BAD..
Bob Miller
- Apr 19, 2003
- New Milford CT
What do you think is the best secondary spring setting?
Buckeye
- Lakes Region, NH
Probably 6-1
RX-Dave
- Nov 14, 2004
I have run mine in several places (stock pink spring) from 40, 50, 60, 70, 80 and find that anything over 60 was causing mine to bind, hurting top end.
- Sauk Prairie, WI
- www.ty4stroke.com
Brian, The settings or twist on a Yamaha secondary are in degrees, not percentages (%) as you refer above. Just wanted to clarify...BBY
