NEWYORKHILLBILLY
- Nov 8, 2014
- Naples,NY
- Viper RTX SE
not sure if anyone posted ....
2016 Yamaha Snowmobiles
See the new lineup Wednesday, February 25, 12:00 PM Eastern.
1tp
- Feb 2, 2014
- Central Wisconsin
- 2015 Viper R-TX LE Clutched and Canned
2014 Viper L-TX SE Clutched
Thanks. Can't wait!
Sr_Viper_RTX_LE
- Jul 8, 2014
- 2015 Sr Viper RTX LE
Any idea what's going to happen? I heard they dropped the weight on the viper to 480 dry and bumped the Hp to 150 with a better exhaust system and higher compression pistons
gytr done
- Jan 8, 2015
- Rx1
There going to need more than a new exhaust and compression bump to get 150 hp from the three holer, unless they up the cc's.
YamaHank
- Apr 1, 2013
- Boston, MA
- 2018 SR Viper RTX
I predict they launch a new motor that is actually designed around the cat pro-cross chassis to solidify the engine supply agreement for a few more years - then if we are lucky a versatile, 100% Yamaha chassis for that engine by 2018 so they can walk away from the manufacturing portion of their agreement with AC.
billbies
12 noon to the dealers via Web launch them info will hit the net
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Allot can be done with the ignition/fuel curve but realistically the motor made 136-138 while in the Nytro. It makes a good 10HP less in the Cat/Viper chassis and most can be pointed at the exhaust and the ignition designed by AC.There going to need more than a new exhaust and compression bump to get 150 hp from the three holer, unless they up the cc's.
