pat the rat
- Mar 13, 2006
went to take off my secondary on my warrior today and it was seized on the shaft.first time this happens to me,i take it off often during the winter and never had it seized.i sprayed wd 40 and let it soak.it finally came loose with some prying and tapping with a hammer.anyone ever experienced this and whats kind of lube can you put on the shaft
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
neverseize.
I used to use never seize, however if you don't clean and reapply in conjunction with the floating clutch, it becomes sticky. The clutch will not seize to the shaft, but may require penetrating oil to loosen the never seize. Now I just use grease.
rage man
i use white lithium grease and reaplly it after every run
pat the rat
- Mar 13, 2006
thanks,ill give it a shot,white grease sounds good.
