Parkstrom
Anyone know what the flashing '85' refers to on my 07 Phazer's self-diagnosis of the electrical system?
Thanks for any help...
Handy
- May 12, 2005
- Anola Manitoba
- 1983 Bravo, 1988 XLV, 1991 Pazer II, 2005 Vector, 2006 Apex Super Charged, 2017 Viper STX DX 137, 2018 SR Venture DX
Code 85 is an open circuit on your oil pressure switch. The plug has probably come loose on the top of the oil pressure switch. Mine came loose when I changed my oil filter for the first time. The switch is located right beside the filter and can get knocked loose when you try to loosen the filter. You have to pull your airbox to get at it.
Parkstrom
Thanks, I'll give it a try...
Parkstrom
Yup, that was the problem - in fact the wire on the oil pressure sensor had been severed somehow. Strange... Thanks for the help.
UP bushman
My wire was damaged when the dealer did the 500 mile service and they hit it with a wrench removing the oil filter.
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Parkstrom, please take the time to update your location in your profile. Thanks.
Glad you solved the problem!
DeepFrz
My father's Phazer FX has gotten this error the past two times we've brought our sleds in for servicing.
