mopar yam
- Nov 10, 2011
Just picked up a 09 rtx se 121 and already have a set of 14.5 rollers does anyone have a good set up for it , springs helix etc ? Thanks
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
I run with a set of 2-speed weights, Yowsers hold on tight!!
mopar yam
- Nov 10, 2011
I'd like to use the stock weights if possible ! Low buck performance !
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Ypy primary spring drill out rivet in tip of weight 45/39 helix and your 14.5 rollers, will give you smooth bottom end and pull hard try it you'll like it
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
What would happen if you just changed the rollers and nothing else?
baggs66
- Nov 18, 2007
- 06 apex gt
It will engage a little lower and your peak rpms will be lower. The smaller rollers will load your clutches harder, you may be able to just use rollers and take the tip rivet out to get your rpms back on top. The pink rate spring will lower your engagement more and make it nice and smooth to ride at low speed their only about $20, you may want to try rollers and remove rivet 1st to see what your peak rpms are, if their low then you would want a higher shift rate on the spring
09nytro
If you don't mind me asking , What did you pay for it ?
mopar yam
- Nov 10, 2011
For the nytro $5800 from a dealer up here with 6000 kms or approx 4000 miles , very clean one owner 96 studs , may add more and some tuners skis . Oh ya it came with blue low windshield and a medium with deflectors too ! Anymore ideas on the clutches would be great guys .Thanks !
mopar yam
- Nov 10, 2011
So do you keep the secondary spring stock or does it have to be changed too ?
nor'easter
- Feb 12, 2008
- Pennsylvania
- Nytro RTX SE
I would call Chris Schmidt at Schmidt Brothers Motorsports. He is a site sponsor. He is an expert in nytro clutch set-ups, and he also sells components for the clutch that you ask about.
baggs66
- Nov 18, 2007
- 06 apex gt
I think that setup has stock pink secondary but I would have to look it's in my sisters sled, I do use the silver secondary spring most of the time .
baggs66
- Nov 18, 2007
- 06 apex gt
We have a Schmidt kit kit in a friends xtx it works well but I think way to expensive for what u get I think almost $400, for$100 for a spring an helix you will be happy and I think it pulls harder than the Schmidt set-up
nytro11tom
ypy spring 14.5 rollers tighten secondary one hole
