Setting Secondary Clutch Angle
YAttak07
Barrie, ON Canada
Any quick tips or step by step instructions on getting the twist angle correct during assembly?
Thx.
angle
on your secondary there's holes marked 1-2-3- now on your helix you can choose what you would like-0-3-6-9 so if you want 3-3 put in holes marked,
then twist til you line up studs push down and start your nuts on then i open secondary a bit so your not on plastic guides.
3-3=60--6-1=70-6-2=80 and go from there. hope this helps.
Seems pretty straight forward then, determine preferred angle based on spring seats and twist till it lines up. Got it.
You have a multi angle helix? I had multi's for my poos with team clutch but I didn't think they had them for these sleds.
Make sure you turn it the right way though, I think it is counterclock wise. hmmm, I think. Hard to remember without the clutch here,lol!!
Anywho, turn it til the helix ramp passes the secondary sheeve ramp then push the helix down & put nuts on.
