Setup "special" Tapex
Jona$
Master
Northern
Sweden
Tapex/sks 800 -16
Gonna race 660 packed snow next weekend and would like to defend my last years nr 1 position.
The thing is i ride out on track like it sat up on trail, but now im gonna tweak it little just in the rear skid but have a few questions.
First the rear is moved back and down for better angel since i use it in deep snow normaly
The rear is sat so the spring is quite stiff ,limiter strap 2 notch up, rebound to about 3/4 to hard and control rod at max ,the electronic shock at about 1/2 .
Launch controll set to about 0.3-0.4bar at launch.
The video below shows the result.
This year i want the skis to plant more to the ground without loosing traction and took one notch up on limiter strap "3" and set rebound at softest. and the ec ohlins to softest.
Should this work or does the rebound,ec ohlins,limiter strap,control rod etc need any else to start with? just started with this since its easy to try out.
It hooks up good but as you see, to much lift in the front costing me time.
Do you se rolling to a full or launch with launch controller as best options?
track is 144x 1.75
