MartyRX1
Hey everyone, I've got an '03 RX1 w/a Bender stage II. Is there suposed to be a shield/plate between the turbo and track/tunnel area?? After riding, the snow which then turns into ice packs up around the turbo and I beleive it's causing my lines to freeze up and boost acting up. The previous owner blew is track and I beleive he damaged what is supposed to be there. Any ideas what I could do here??
yes, they just rivet a peice of alumnum there. square plate. if you cant make it call full power
thinksnow
Just make one out of sheet metal and rivet it into place. It doesn't need to be fancy. Just needs to keep the majority of the snow out. Drill a couple small holes in the low spots to let any water that does get in around the turbo to flow out.
