SISCAKIDD
Do any of you guys know if the front GYTR clicker shocks off a standard FX NYTRO will fit on a Phazer ,i think they would bolt right on but want to be sure before i sell to a friend.
hossZ28
Still has a yamaha powerplant!
- Feb 6, 2009
- Ontario Canada
- 2014 Arctic Cat XF 7000 LTD
Take one off of each sled and compare the length differences
Sorry, Nytro and Phazer shocks are very different. The Nytro shocks are much too long.
Nytro extended 17.5" Travel 5.37"
Phazer extended 15.9" travel 4.92"
Additionally, the lower mount is a different width.
SISCAKIDD
Thanks ,thats what i needed to know.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
bjowett said:Sorry, Nytro and Phazer shocks are very different. The Nytro shocks are much too long.
A good shock guy can shorten the shafts not that hard. Can be done pretty cheaply
Unfortunately, most of the length is in the body, which is not hard to shorten either. But then add shortening the shaft, and the Nytro lower mount being 6mm wider.... and it starts to get into a little more than bolting them on.
- 16K
- 7K
