sledmaine
- Mar 1, 2008
I would like to know the differance between the GYTR dual clicker shocks and the KYB aluminum HPG shocks....is one rebuildable or are they both and would one make the sled handle better then the other?....thanks for any information
Phantom
- Apr 2, 2004
Both are rebuildable...
The GYTR Clickers are externally adjustable.
The KYBs must be disassembled and re-valved to change settings.
ragefarmer
on my 05 rage i have the hpg shocks, i have a set of ohlins res. shocks but there 3 inches shorter, would this help inside ski lift to use the ohlins or would that not be an advisable switch. by turning the lock nut i could lower the hpg by 1-3 inches, but i thought maybe the ohlins would be a better upgrade.
sledmaine,Please take a moment to fill in your profile location as it's required by all members.Thank You
