MajorGasAttak
I'm looking to buy a shop dolly and was wondering if anybody has moved an Attak around with one. I know that older dollys were'nt as wide as some are today, I do'nt want to get stuck with the wrong item. Also how does the lenght and pointy tailight come into play? (Save your key strokes if you want to suggest a 3 pack of mobile rollers) Thanks
2BLUE4U
I have a newer shop dolly that I purchased last year. Mine is adjustable. I will check it out on my attak tonight.
jtssrx
I had a 136 RX-1 "warrior" And I have a "easy Mover" It works great with it.
Superman
jtssrx
I had the one in the picture. I switched to the Easy mover. It works 100 times better. You can't get the pads on the one in the picture under the sled far enough
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
We use the one in the picture above on all our race sleds and it works great, I'd recommend it!
MajorGasAttak
jtssrx said:I had a 136 RX-1 "warrior" And I have a "easy Mover" It works great with it.
I looked that one up, it looks kinda strange. For the same price you can get a traditional dolly with larger tires. Whatever works for you. Thanks for the help.
jtssrx
MajorGasAttak said:jtssrx said:I had a 136 RX-1 "warrior" And I have a "easy Mover" It works great with it.
If you have a Snowmobile USA show in your area I suggest you go there and check it out. The easy mover people are at every show and you will get a better Idea why it's a better dolly.
You can get the big tires for the easy mover as well
myyamaha
I have a easy move I don't really like it that much U have to see the jack rollerhttp://www.industriesjack.com/1enprod2e.htmbest U can use to move a sled I work at a dealer and that's what we us!
STORM-CHASER
This is the one I like.
Fits around the vector I used extra pads to make it lift higher.
http://www.korkys.com/Merchant2/merchan ... ory_Code=S
BlueLightning
Has anyone tried these on the Attak or Apex. I need a dolly and a jackstand to keep the track off the ground. Any more suggestions. I want to make sure it fits right under the new sled so i dont hurt the plastic.
Yamadog
I have the one pictured with the models and bought it from Korky's on special $129 and free shipping. $60 cheaper than shadetree $200 cheaper than dennis Kirk. It works great on my Apex and all other sleds.
Ole Timer
Easy-Mover ! Cheaper, better. easier and uses less room to store ! If your on cement or blacktop standard wheels are good. Gravel or dirt needs bigger optional wheel kit.
