outofbounds
I just installed a set of Gen II skis on my 08 Nytro. From first-hand experience can any of you answer:
- Does the width negatively affect counter-steering?
- Do the wide skis make it harder to push the sled back up after it's been tipped over?
- Do they make side-hilling more difficult?
They look so damn wide that I am a bit worried that the negatives might out weigh the positives. (and, yes, I should have more important things to worry about).
Thoughts???
Thoughts???
BBNytro
1. They do affect countersteer a little nit
2. slightly
3. Depends on how sound your technique is
There is a mod I've seen on Snowest where you cut about 6 to 8" off of the outer rear part of the ski which would really improve 1 and 3
2. slightly
bholmlate
Outofbounds
The stock mountain ski is +/-7 inches wide and the Simmons Gen II ski is roughly +/- 10 inches wide. So in reality we are really only talking about 1 1/2 inches wider of a ski since the spindle mount is more or less in the center of both skies. I think it is more psychological then anything becasue they do look big
the only area that i found that they made things a little more difficult was maneuvering at slow speeds on packed snow becasue of the two keel design .
I am happy with mine and think they made a positive improvement to my sled.
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Had them on my Turbo Apex, and they really helped on that sled. It really like to pull straight though... With that being said, I think Ill be buying Powderhounds this time around if I buy skis..
outofbounds
I have been obsessing about the possible minor negatives to the Simmons GenII skis – counter steering and side-hilling.
My skill level is getting there but at this point I am looking for every advantage I can find.
This mod picture was posted on one of the Snow West forums. It seems like the way to go.
I was hoping to get some feedback prior to pulling out the cutting tools.
This is the link:
http://www.snowest.com/forum/showpost.p ... stcount=10
This is the link:
murph
bholmlate: Let's ride Tahoe together sometime....I want to try those Simmons Gen 2's you have and you can try my Powerclaw 162"
Murph
motogpmurph@yahoo.com
Murph
