Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
What is the proper way to adj the skies for the Snow Trackers as I heard that it should be 0 Toe in/out??
My 2017 is within 1/4, but my 2022 is way off.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
0 toe in/out - what snowtrackers excel at is creating a new track that is easier for the ski to follow. It does so by filling in the tracks in front of you and the deep keel cuts below other tracks.
Toe in will make the sled run straighter
Toe out will make initial turn in easier at the expense of straight line stability
This is true for cars as well
If you have too much toe-in the sled will be hard to turn in and when you do get it to turn, it may promote understeer (push) in corners. Too much toe out and you risk the sled being unstable, exaggerating oversteer in corners and will make the sled feel loose. Snowtrackers can magnify these effects which is why you want zero toe. Having said that, these are not precision steering instruments nor is snow a high traction medium so get it as close as you can to zero.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
It should be 0 degrees for SnowTrackers. I have them on my Viper and they work great.
Snorover
- Apr 15, 2003
- 2017 Viper
I guess I should have asked just how to adjust the skies, with weight on or off for the adjustment and adjust both sides equally??What is the proper way to adj the skies for the Snow Trackers as I heard that it should be 0 Toe in/out??
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
I snapped a chalk line on the floor as a reference (lengthwise with sled) and adjusted the skis with the weight of the sled on them although it shouldn't make a huge amount of difference.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Here’s a pretty good link.
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
All above is good info. If you have an older sled with a bit of slop in the steering I recommend a bungy across the ski tips to make sure you don't go beyond 0 toe in.
rb2001srx700
- Dec 17, 2015
- BALLSTON SPA
- 2001 SRX 700
I am looking at a set for my 2020 viper. How do they fare on blacktop? There were a few roads I crossed and wiped out the regular skaggs in a hurry. Thanks for the feed back
rocky18
- Jan 28, 2012
- Rockford, IL
- 1997 Yamaha 600 Venture
2012 Yamaha RS Vector LTX (R.I.P)
2018 Yamaha SR Viper L-TX-DX
- Just below the Cheddar Curtain
These things are amazing...Blacktop? not a problem 2018 Viper, 4000 miles, still serviceable...sled handles extremely well.I am looking at a set for my 2020 viper. How do they fare on blacktop? There were a few roads I crossed and wiped out the regular skaggs in a hurry. Thanks for the feed back
