Is it worht the price to change out the ski springs to Maxximum preformance straight rate springs. Do they make a big difference.
Black 1000
Huge. Do you have the longer links? Make sure your preload is backed off when the ski hangs.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Be sure to get the heavier (thicker) 13mm stabilizer bar, and easy spring adjuster collars too. Then cover up the shocks with those nylon covers as this will prevent debris from mucking up the threads, making it difficult/impossible to adjust your pre-load.
