I have an 07 attak with mods. but none to tunnel or skid.
I was wondering if any of you guys have put drop brackets on the sled yet? the reason why I want to do this is cause I have a 1.5 inch lug. and I just installed timbersled exhaust and there is about 3/4 of an inch, away from the pipe and its not enough room for comfort. So I was wondering if anyone has installed any? if so what kind? I like wrenchin so it not a problem if its a hard job.
Another reason, is when you look at where the drop brackets are replacing. the Oem ones that are there on the attak are bent kind of in so that the shaft that goes from the upper idler wheels across from one side to the other fits under the tunnel.. and I have timbersled drop brackets. but I dont kno if you need any other ones.. cause they look like it would put the track at to much of an angle.. and so you would have to do the other top brackets to.. so all in all there would be four brackets dropped.. but if you have any ideas or what have you done it would be deeply apericated..
just need more clearnce in the top of the track and the tunnel! dont need much!!
sorry its not clearnce between track and tunnel, but track and exhaust pipe that I put in. I have been running the track at 1.5 for 2000 miles no problems, but exhaust is lower then tunnel and probably about an 1 inch of clearnce maybe..
