canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Just wondering if anyone here has a stock set of mountain skis or something wider than the stock 5" trail ski they might be willing to sell/trade. I've check in the classifieds but not everyone looks there. I'd like the mounting hardware to if possible.
Nikolai
Look for a set of Polaris Gripper skis. They're 7" wide, and over 4 lbs lighter than MTX skis, plus they handle a little better. I've seen used and new-takeoff sets go for less than $200.
4strokesmokextx
what do you need to run the grippers?
canoehead
- Jan 14, 2011
- NE, Alberta
Good point!4strokesmokextx said:what do you need to run the grippers?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Nikolai said:Look for a set of Polaris Gripper skis. They're 7" wide, and over 4 lbs lighter than MTX skis, plus they handle a little better. I've seen used and new-takeoff sets go for less than $200.
Interesting,
Nikolai, are there any mods required to make the Gripper ski fit the Yammy spindles?
Bill
Nikolai
You have to narrow the spindle bushings and I used the Polaris rubbers, but I'm pretty sure the factory rubbers would work if you narrowed them. They aren't anything special, but if your looking at swapping MTX skis you might as well get the Grippers for the weight loss.
will 6.9 pilots work?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
Thanks for posting the pics Nikolai
How would you rate their floatation and side-hilling performance when compared to the MTX ski?
Looks to be another good way to shave some more pounds off of the front end
Bill
Bill
Nikolai
Flotation should be the same as they're both 7" wide. Sidehilling I think they're a little better. Most of the improvement I noticed was on the trail though.
LoneViper
Nik, are you running a Timbersled front end? For some reasion I thought had the Skins front end. If you have had both, which do you like better?
Sorry about the off topic, just courious.
canoehead
- Jan 14, 2011
- NE, Alberta
First thing I thought was BarkBusterLoneViper said:Nik, are you running a Timbersled front end? For some reasion I thought had the Skins front end. If you have had both, which do you like better?
Nikolai
Those are old pics, I do have the Skinz front end and it was a big improvement over the Timbersled.
