Paraclete
Got my new lift today from Ohio Chassis. Great lift HORRRIBLE SELLER.
TOOK 2.5 MONTHS TO GET IT.
I have a couple of issues.
I had to crank it up with my metric adjustable wrench since I did not have a socket big enough
Lift will not fit under the arm thingy in second pic
I added 2*4 under running board to keep it level
The rear extensions are less than halfway down the boards IDK if that is ok
I need a fudging shoulder surgery after cranking that biatch up
![Banghead :o| :o|](/styles/default/xenforo/smilies/banghead.gif)
Nick1945
I bought the same lift, from the same place, about a year and a half ago, and the crank handle that came with it, had the socket on it, and it works very easy. Free shipping, was here in 3 days, but its not that far from me, only 150 miles.
Its a 15/16" socket, btw.
judger101
cant you just use an impact wrench to raise and lower it? seems like it would be much faster and easier on the shoulders! ![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
ArcticWhite
- Sep 25, 2007
I have the rec lift that is very similar. Do not use an impact wrench on it. It will wreck the lift mechanism with the hammering. I have been using an 18v cordless drill on mine for the last 5 years with no problems. Really saves on the effort.
Paraclete
Yeah I just need to get a bigger socket.
MM just under 1"
MM just under 1"
weld a socket to a 3 foot extension put on a electric drill works great.
Paraclete
anybody know what size before I go by a cheap one to weld on?
