Sleds lifts?
My sled lift is about the same, except where it meets the running boards, it has two large circular rubber pads attached. You could just place a couple of pieces of 2X4's over the pegs where it meets the running boards if they happen to line up on the heat exchangers.
I made up a set of rear pads for my lift.
I replaced the small rubber rear lifting points with hockey pucks. It spreads the force of the lifting out over a wider area.
