Ride On
- Jan 26, 2015
- Burlington, Wi
- 2015 Viper LTX LE
Anyone using these? Looking for some "real-world" feedback. I'm still having some push issues, wondering if these would help?
Current settings. (200lb rider)
70lbs in front (float 3's)
Limiter pulled up to 3rd hole (seems too tight & losing suspension)
Center on full soft
Rear on softest(tried on #2= very stiff)
Bergstrom 8" + round bar on outside
Center on full soft
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
I have a set no push but i run c&a xtx had last year no problems so far, i think the skis you running make the sled push .my friend tryied a set of tunner skis on his nytro for couple rides and sold them because they pushed heavy but no darting
Ride On
- Jan 26, 2015
- Burlington, Wi
- 2015 Viper LTX LE
Thanks for the info
I had 6+4" carbides on 1st but had bad push, had good luck in the past with the Bergstrom TP's, but still not gaining on the push, damn hoping the Tuners would work!
gpxsrx
- Dec 15, 2009
- way to many 2 strokes
I have a set of saddleless arctic cat skis and 9inch shaper bars. Had them from my Sno Pro 720 no issues no push or darting. did not want tuner ski's.
limiter straps on 3 hole
front shock loosened
blocks on #3
Still way to much ski lift, darting and pushes in corners.
Heard curves skis help
mine is a R TX 129
blocks on #3
mine is a R TX 129
SISCAKIDD
Get a set of curves....you will not be sorry
gpxsrx
- Dec 15, 2009
Th
Thanks I have heard that also but they are out of black right now.Get a set of curves....you will not be sorry
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
So anybody have the Slicast arms?
vsmpowered
- Feb 16, 2009
- Rochester , NY
I have set
ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Put tuners on friends ltx 4&6. bad push then on a road front end washed out, caught an edge and fliped him over. In an attempt to get him back to the truck we tightened the preload on the front track shock to unload the skies. could live with the push but not the catching. It may seem wrong but it fixed it. no more push handeled great. he is going to keep them. ran into a guy with a 15 rtx having the same problem adjusted his shock with same result. they dont seem to like too much pressure. something to try.Thanks for the info
tapex_07
- Feb 15, 2009
And.....?? What are your thoughts?I have set
