RTX Meirda
Just noticed a crack in the slide rail near the front wheel on my 09 Nytro RTX SE.
Anyone else have this happen?
Were there any updates or service buletins that I may have missed?
mach9
I have seen this but at the top edge of the rail by the hole only. I'd say after a blown shock chances are higher.
RTX Meirda
This is right above the bolt for the front wheel.
The sled rides so good, I guess i dont feel the bumps.
epoxy
- Nov 9, 2012
I noticed a crack on each of the slide rails in front of the "YAMAHA DAMPER 2 Part Number: 8GL-47457-00-00"
Hopefully the weld will hold this winter and I can get some new rails for the next.
AKrider
I cracked the rear of the rails on my '05 Vector. The stock, non-rebuildable shock was garbage but I knew that from the get go. I bought and installed a piggyback rear shock out of the '06 Nytro but it wasn't enough to prevent the bottoming. Basically if you are bottoming a lot, things get beat and break. I learned this the hard way.
