Just looking for some input as to why i am getting a bit of a hesitation on take off some times ? I am thinking jetting is needed but i would like to hear your opinions. Also the sled was just fully serviced(carbs cleaned etc), all under the hood is stock and the pipe is the excell.
bedwet
did you change jetting at all?
thrasher
- Nov 22, 2006
- Ottawa Valley, Ontario
- 06 Vector RS ER
What's your rpm at idle when warmed up? If much below 1500 rpm you may get some bogging on take off.
No i did not change jets, they are still stock. As far as rpm at idle i am going to have to check in the morning
bedwet
you should go up on your jetting, not sure what size to go to im sure someone will jump in and help out
RPM's are right on 1500 when warm
Len Todd
With the new pipe, you may have to increase your fuel mixture. You might want to call Excel and ask them what they recommend. It could be that all you need to do is turn out the fuel screws a tad. Or, ... maybe lower the clip on the needles. Or, ... maybe you need to go up one size on the Mains. So, ... the best place to start is with the people who sold you the pipe.
Thanks alot guy's thats the kind of info i was looking to hear. I am hoping for a correction with the turn of a screw or somthing, I will give excell a call.
- 8K
